Scenes
Can I modify scenes defined in LM in visualisation?
I mean change of brightness, room temperature etc.
"Autolearn" button would be great too.
Thank you
Hi Thomas,
Not yet (for now you need to login to configuration part), but i have plans to create a app for this so end user can change and define his own scenes.
Can I access scene objects from Lua? If so I can simulate the required "Save" button in this way.
Available functions:
scene.run = function(alias)  run scene, alias can be a name or an id scene.savelive = function(alias)  save live value for the given scene alias scene.set = function(alias, active)  enable/disable scene, this will only disable running the scene  by sending a specified value to trigger object. scene can be  still executed via run() no matter if it is enabled or not scene.enable = function(alias)  shortcut for scene.set(alias, true) scene.disable = function(alias)  shortcut for scene.set(alias, false) scene.status = function(alias)  returns true when scene is enabled, false otherwise scene.tagset = function(tag, active)  enable/disable all scenes having the given tag scene.tagenable = function(tag)  shortcut for scene.tagset(tag, true) scene.tagdisable = function(tag)  shortcut for scene.tagset(tag, false) scene.tagstatus = function(tag)  returns two values: number of enabled and disabled scenes  for the given tag scene.tagsavelive = function(tag)  save live values for all scenes having the given tag scene.tagrun = function(tag)  run all scenes having the given tag
How can I use these functions? What do you mean by scene object? 1byte object?
This is only available in newer firmwares which are not published yet
(23.02.2017, 18:06)admin Wrote: This is only available in newer firmwares which are not published yet
Super info, I am waiting for publishingWink
Hi Admin,
Will there also be a mapping option added for 1 byte feedback to 1 byte value when using 4bit dimming? Issue is when you use 4 bit dimming from sensor the feedback is update only, and value object doesn't have this latest value. So when you save live values the value object might have different value then the real dimming value (as send by feedback object).
I noticed also the function scene.reload() that is not specified in your list, what does it do?
Reload is used to tell the scene handler to reload scene data from the database. It is used by functions like enable/disable and should not usually be run manually. For now status objects won't be supported, but we might look into it later on.
please add timouts between sending telegrams Smile
Can I get scene table by some search function? Like I can use
myobjects = grp.tag('tag name')
for getting a list of group objects tables.
Thank you
Do you want to get get a list of all scenes? Then the only way for now is to a database query:
scenes = db:getall('SELECT * FROM scenes')
(29.11.2017, 07:28)admin Wrote: Do you want to get get a list of all scenes? Then the only way for now is to a database query:
Thank you
(23.02.2017, 16:31)admin Wrote: Available functions:
I am not able to do this.  I every time get an error stating; attempt to call field 'savelive' (a nil value)
The code is
if scene > 0 and scene < 63 then   scene.savelive(navn) end
Am I missing something, or just doing it wrong?
That's because you have overridden scene table with a numeric variable, rename scene number variable to something else in your script.
(28.07.2020, 11:00)admin Wrote: That's because you have overridden scene table with a numeric variable, rename scene number variable to something else in your script.
Of course...
Thx for the patience  Blush
