24.07.2023, 13:48
Every LM version has same sw so if it work for Todayslife it should work for you.
EnOcean USB 300 stick
24.07.2023, 13:48
25.07.2023, 15:19
25.07.2023, 15:20
No you must install it manually from additional packages.
26.07.2023, 16:50
(25.07.2023, 15:20)Daniel Wrote: No you must install it manually from additional packages. Can you link me where i can get the extra package for my SW version 20210521? Is the genohm-scada-enocean_20230316 package in this page https://dl.openrb.com/lm-23-imx6/pkg/ ?
26.07.2023, 17:23
Yes, make sure you use version for your hardware
imx6 https://dl.openrb.com/lm-23-imx6/pkg/ imx28 https://dl.openrb.com/lm-23-mxs/pkg/
27.07.2023, 13:24
(26.07.2023, 17:23)Daniel Wrote: Yes, make sure you use version for your hardware Done. Installed it. It seems to work but why isn't there any profile for A5-20-01 eep? Is there any method to make it work?
27.07.2023, 14:12
27.07.2023, 15:01
(27.07.2023, 14:12)Daniel Wrote: See this Thanks Daniel, i'll take a look forward.
31.07.2023, 11:03
(27.07.2023, 14:12)Daniel Wrote: See this Hi Daniel, Do you know if this gateway as a limit number of devices working toghether? Rn, i'm managing around 10 devices with various profiles and it seems to work great. I've done a test in the last two days and i never got an error/alert, with the devices always online and communicating. Please let me know BR
31.07.2023, 11:38
There is a limit for 128 sending devices but as always the CPU/Memory is the limit to watch for.
01.08.2023, 07:17
