Split string over multiple lines
Hi All,
Wondering if it is posisble to split a long string say 120-150 characters over a couple of lines dependant on width and display in a multiline object.
Cheers,
Paul
What is your display? Is it webbrowser or some KNX device?
For dividing string in lua you can use such function:
> = string.sub("Hello Lua user", 7)      -- from character 7 including 7 until the end
Lua user
> = string.sub("Hello Lua user", 7, 9)   -- from character 7 until and including 9
Lua
> = string.sub("Hello Lua user", -8)     -- 8 from the end until the end
Lua user
> = string.sub("Hello Lua user", -8, 9)  -- 8 from the end until 9 from the start
Lua
> = string.sub("Hello Lua user", -8, -6) -- 8 from the end until 6 from the end
Lua
Done is better than perfect
I'm using a browser, so somehow I want to put the string with newline characters into a user param and display.
Cheers,
Paul
Note that this will not work in editor only in normal visualization view.
Set Display mode to value for your object and set Additional class to longtext
Add to Vis. graphics > Custom CSS, adjust width (250px) as needed:
.longtext {
  width: 250px;
  text-align: left;
  white-space: normal;
