12.02.2020, 11:07
(This post was last modified: 12.02.2020, 12:49 by fleeceable.)
Hello!
Usually I can dig through the problems but this time I need your help guys.
I have Synology NVR and Hikvison cameras. I have tried two scenarios to show cameras in visualisation.
1) I used second mjpeg stream from hik cameras but it works only once when I click camera icon. Popup will occure and I see picture. When I close camera stream and open it again - blank picture. I know that hik supports one client on one stream. Looks like visualisation doesn't end the sream when I close camera popup. After page refresh it will only works again once.
2) I have used synology Surveillance Station api but looks like api sid will expire and stream is not working. What is interesting part is that one stream will work after days, other camera links are broken.
In system I have 5 cameras.
LM Version: 20190904
Do you have any ideas what to try or solution for that?
Kristen
Kristen
