Remote access to USB drive
I can write to a USB drive, then unplug it and read the contents on another computer. However, Is there a way to reads the USB drive contents remotely?
I was thinking to FTP in via the apps' credentials, and this allows me to see the /user directory. I can see files I have put into that directory via previous FTP sessions.
However, can I FTP my way to the USB contents? Or, as second best, how to write the code to copy a file from the USB dive to the /user directory, which I can then retrieve via FTP.
I have been playing with the following code:
1234567891011121314151617181920212223242526272829303132
-- Write a test USB stick file res, err = mount_usb() log('After mounting, result is', res, err) if res then   f, err = io.open('/mnt/testfile', 'a')   if f ~= nil then         f:write(os.date("Starting log at %X on %A, %d %B %Y")..'\n')     for i = 1, 10 do       f:write('Hello!'..'\n')     end     f:write(os.date("Finished log at %X on %A, %d %B %Y")..'\n')        f:close()     log('Wrote to USB drive')   else     alert('Unable to write to file: ' .. err)       end   os.execute('cp /mnt/* /user') -- doesn't work   os.execute('touch /user/Test.tst') -- doesn't work   os.execute('touch /mnt/Test.tst') -- works!   os.sleep(2)   log('finished')   unmount_usb()   else   alert(err) end
The first lot of code works and creates the 12 line file on the USB stick. The other os.execute commands either work or don't work as shown. Am I heading down the right path?
So, my questions summarised:
1) Can we reach the USB drive directly via FTP?
2) Failing that, can we copy files from the USB drive to the /user directory?
Thanks!
No, that is not possible, but you can write your file directly to the ftp
See this sample: https://openrb.com/example-export-last-h...-from-lm2/
Thanks, Erwin. There's a lot of examples and ideas there!
This is possible, you just need to mount the USB drive correctly. Note that example uses paths for ftp username, not apps. If using this approach you only need to mount USB drive once and do not unmount it after writing.
-- create directory. os.execute('mkdir -p /data/ftp/usb') -- mount usb drive os.execute('mount /dev/sda1 /data/ftp/usb/ -o dmask=0000,fmask=0000')
