Event Script BUS reset
Hello
I have a problem, I have created various scripts on event for the alarms that send me e-mails and SMS, but in case of bus reset all the messages leave me, how can I delay sending messages in case of bus reset?
Inside the event scripts?
I'm not sure if I understand you correctly. If you want to check if object value is still the same after a short delay then you can use this script:
value = event.getvalue() -- alarm triggered if value == true then   os.sleep(5)   value = grp.getvalue(event.dst)   -- alarm still triggered   if value == true then     -- do something here   end end
