Calculate average value using tag
I would like to sum up 8 volume values. To know the actual values of the air flow in total.
Earlier i have used this script with same tag on the adresses and the event script:
T1 = grp.getvalue('xx/x/xxx')
T2 = grp.getvalue('xx/x/xxx')
T3 = grp.getvalue('xx/x/xxx')
T4 = grp.getvalue('xx/x/xxx')
T5 = grp.getvalue('xx/x/xxx')
T6 = grp.getvalue('xx/x/xxx')
T7 = grp.getvalue('xx/x/xxx')
T8 = grp.getvalue('xx/x/xxx')
AV = math.round((T1 + T2 + T3 + T4 + T5 + T6 + T7 + T8) / 8, 0)
grp.write('xx/x/xxx', AV)
Just wondering if there is a simpler way, to do this?
Later using the total actual value on the total 8 supply vav. And converting it into a setpoint for one extract vav. But that is on a later point.
Just use this
https://forum.logicmachine.net/showthrea...18#pid1518
