12.09.2021, 06:15
(This post was last modified: 12.09.2021, 06:16 by pioneersteffen.)
Hi @all,
I’m starting to generate a widget based visualization and I having three issues:
Many thanks in advance.
Best Regards
Steffen
- Widget Shutter Vertical: The first four object settings are clear and working fine. Unclear is Movement and Stop object. I tested different group address functions but all the time the up and down arrows didn’t work. What is the meaning behind the objects? I used a MDT Shading actor, what is the right function (list attached) for this two objects?
- CO2/humidity/temp sensor: I want to set the humidity group address but in the drop down selector it isn’t shown. Pictures attached. How can I solve this?
- General question: Is there a user guide with some description for any widget?
Best Regards
Steffen
