HONEYWELL METER - MBUS
Hi again:
I have a new question.... We have an installation with Honeywell meters. They have 3 address - primary1 primary2 and second. Primary 1 is 0,  but primary2 is the last two number of its serie number.
My question is, how to use primary2 to getdata from the meter? I use getdata and didn't get any result. I don't know if someone has used this type of meter. Basically is for not change the address of every meter and use de primary2 instead.
Thanks a lot....
Try running the bus scan first. Disable any other script that might be using mbus (only a single script can access the bus at any time). You might also need to change the baud rate, check the meter documentation for this.
require('mbus') mbus.init('/dev/RS232', 2400) res = mbus.scan(0, 254) log(res)
