TP load flooding Bus
Hi everyone,
I found it strange on my LM that every-time a telegram send to bus for an event always cost least 10 telegrams which make TP load spikes. My TP load always not flat and stable. Could anyone give a hint on this situation. Best thank you
Do you have another KNX router connected there? Could be KNX loop.
(09.11.2021, 14:43)Daniel Wrote: Do you have another KNX router connected there? Could be KNX loop.
Yes D!
I have only 1 KNX Secure router work as IP gateway to the Bus. Is this because of this ? If i take it out. How the KNX bus be accessible from Lan ?
Change the multicast on LM then both can work together. Why do you need this extra router when LM can do the same?
(09.11.2021, 15:13)Daniel Wrote: Change the multicast on LM then both can work together. Why do you need this extra router when LM can do the same?
I got this now D, i never know such! Very simple and great device, LM.  Thank you for you support! Have a good day.
