29.06.2022, 09:30
Greetings
I am using reactors to supervise only the inputs on board, not having connected the TP I always get the error message when I connect and the CPU load is always high, if I switch to IP everything works, without problems, scripts etc. etc .., even remote access with ZeroTier
Thank you
Thank you
