Swimming pool Scheduled script
Hello everyone,
hope you're doing well.
If I have a swimming pool with 2 motors (M1, M2) and I need to make the following:
-Weekly only 1 motor works. (ex: Week 1 --> M1, week 2 -->M2, etc)
-In Summer: ON for 1 hour,  off for 1 hour then repeat till the end of the day.
-In winter: ON for 1 hour,  off for 2 hours then repeat till the end of the day.
I already make it with the schedulers but I couldn't make it with scripting!
any ideas, please?
Thanks for your time.
How is winter/summer mode set? Via an object or calculated based on current date?
(11.10.2022, 13:01)admin Wrote: How is winter/summer mode set? Via an object or calculated based on current date?
Thanks for your reply,It will be based on the current date.
So which months should be included in the summer mode? June-August or something else?
(11.10.2022, 13:19)admin Wrote: So which months should be included in the summer mode? June-August or something else?
yes from June to September.
Create a scheduled script that runs once every hour:
addr1 = '1/1/1' addr2 = '1/1/2' week = tonumber(os.date('%W')) hour = tonumber(os.date('%H')) month = tonumber(os.date('%m')) -- swap outputs on even weeks if week % 2 == 0 then   addr2, addr1 = addr1, addr2 end -- summer mode (June 1st to August 31st) if 6 <= month and month <= 8 then   on = hour % 2 == 0 else   on = hour % 3 == 0 end grp.write(addr1, on) grp.write(addr2, false)
(13.10.2022, 06:48)admin Wrote: Create a scheduled script that runs once every hour:
Thanks for your reply, It's working well, but I need to study it!
Thanks again for your support.
