I've tried to gather best practices across the forum on writing non-blocking loops to handle events from mqtt / bus and timer events in order to write constantly running logic for sending / receiving / syncing data or similar. I've come up with user library below that simplifies API to initiate and attach to event sources. Hopefully it will be useful to others.
Usage (put code below in a resident script, timeout doesn't matter since loop never leaves):
Create user library 'user.eventloop'
local mqtt_cfg = {
  broker = 'IP',
  login = 'USERNAME',
  pwd = 'PASSWORD',
  id = 'CLIENT_ID',
  topics = {'zigbee/+', 'zigbee/bridge/config'},
-- alternative for single topic subscription
-- topics = 'zigbee/+',
function mqtt_onmessage(mid, topic, payload)
-- logic
function localbus_onmessage(event)
-- logic
function on_timer()
-- logic
function setup()
  local lp = loop.get()
  -- use one or more of the below in any combination
  -- mqtt client with callback function to receive messages
  -- store mqtt.client to local variable if you want to publish messages later
  local mqtt = loop.create_mqtt(mqtt_cfg, mqtt_onmessage)
  -- add 'groupread = read_callback' to add read callback handler
  local bus = loop.create_localbus({ groupwrite = localbus_onmessage })
  -- timer that fires callback every 10 seconds, period can be a fraction of a second
  local timer = loop.create_timer(10, on_timer)
  -- add all workers to our loop
  lp:add(mqtt)
  lp:add(bus)
  lp:add(timer)
setup()
-- run loop forever until script is terminated
loop.get():run_loop()Create user library 'user.eventloop'
socket = require('socket')
local function safe_callback(callback)
  return function(...)
    --return callback(...)
  local res, errMsg = pcall(callback, ...)
    if(not res) then
      error(string.format('unhandled exception: %s', errMsg))
    return res, errMsg
package.preload['user.eventloop.loop'] = (function(...)
    local loop = {}
    loop.__index = loop
    function loop:add(worker)
      self.workers[#self.workers + 1] = worker
      if(worker.on_add) then
        worker:on_add(self)
    function loop:remove(worker)
      local w = self.workers
      for i = 1, #w do
        if(w[i] == worker) then
          table.remove(w, i)
          break
    function loop:prepare_fds()
      local fds = {}
      local actions = {}
      for i = 1, #self.workers do
        local v = self.workers[i]
        local fd = v:get_fd()
        if(fd) then
          fds[#fds + 1] = fd
          actions[#actions + 1] = v
      return fds, actions
    function loop:run_loop()
      while(#self.workers > 0) do
        local fds, actions = self:prepare_fds()
        local res = { socket.selectfds(10, unpack(fds)) }
        -- first result is true if returned something, nil if not
        if(res[1]) then
          for i = 1, #fds do
            local fd = res[i + 1]
            if(fd) then
              actions[i]:step(fd)
    function loop.create_timer(...)
      return require('user.eventloop.timer').new(...)
    function loop.create_localbus(...)
      return require('user.eventloop.localbus').new(...)
    function loop.create_mqtt(...)
      return require('user.eventloop.mqtt').new(...)
    local instance
    function loop.get()
      if(not instance) then
        instance = setmetatable({}, loop)
        instance.workers = {}
      return instance
    return loop
  end)
package.preload['user.eventloop.timer'] = (function(...)
    local timer = { type = 'timer' }
    timer.__index = timer
    function timer:get_fd()
    return self.fd
    function timer:step()
      -- disarm timer
      self.timer:read()
      self.callback()
function timer:on_add(loop)
      self.loop = loop
    function timer:stop()
      self.timer:close()
      self.loop:remove(self)
    function timer.new(interval, callback)
      local t = setmetatable({}, timer)
      t.callback = safe_callback(callback)
      t.timer = require('timerfd').new(interval)
      t.fd = socket.fdmaskset(t.timer:getfd(), 'r')
      return t
    return timer
  end)
package.preload['user.eventloop.localbus'] = (function(...)
    local lbus = { type = 'localbus' }
    lbus.__index = lbus
    function lbus:get_fd()
      return self.fd
    function lbus:step()
      self.bus:step()
    function lbus.new(handlers)
      local b = setmetatable({}, lbus)
      b.bus = require('localbus').new(1)
      if(handlers.groupwrite) then
        b.bus:sethandler('groupwrite', safe_callback(handlers.groupwrite))
      if(handlers.groupread) then
      b.bus:sethandler('groupread', safe_callback(handlers.groupread))
      b.fd = socket.fdmaskset(b.bus:getfd(), 'r')
      return b
    return lbus
  end)
package.preload['user.eventloop.mqtt'] = (function(...)
    local bind = function(obj, func) return function(...) func(obj, ...) end end
    local mqtt = { type = 'mqtt' }
    mqtt.__index = mqtt
    function mqtt:get_fd()
      if(self.soc) then
        return socket.fdmaskset(self.soc, self.client:want_write() and 'rw' or 'r')
        return nil
    function mqtt:on_add(loop)
      -- need to do misc() every second according to mosquitto doc
      local timer = loop.create_timer(1, bind(self, self.step_misc))
      loop:add(timer)
    function mqtt:step_misc()
      if(self.soc) then
        self.client:loop_misc()
        self:connect()
    function mqtt:step(fd)
      if(socket.fdmaskread(fd)) then
        self.client:loop_read()
      if(socket.fdmaskwrite(fd)) then
        self.client:loop_write()
    function mqtt:connect()
      self.client:connect(self.broker)
      self.soc = self.client:socket() or nil
    function mqtt:on_connect(success)
      if(success) then
        log('connected to MQTT')
        if(type(self.topics) == 'string') then
          self.client:subscribe(self.topics)
          for i, t in ipairs(self.topics) do
            self.client:subscribe(t)
    function mqtt:on_disconnect(...)
      log('mqtt disconnect', ...)
      self.soc = nil
    function mqtt.new(cfg, msg_callback)
      local m = setmetatable({}, mqtt)
      m.client = require('mosquitto').new(cfg.id)
      m.client:login_set(cfg.login, cfg.pwd)
      m.client.ON_CONNECT = bind(m, m.on_connect)
      m.client.ON_DISCONNECT = bind(m, m.on_disconnect)
      -- callback have (mid, topic, payload) arguments
      m.client.ON_MESSAGE = safe_callback(msg_callback)
      m.broker = cfg.broker
      m.topics = cfg.topics
      return m
    return mqtt
  end)
return require('user.eventloop.loop')
