Adding to the Pull Down menu in Touch
Is there a way to add an option in the pulldown menu in the touch interface to perform an action as setting a Objectvalue to a certain value or maybe run a function in javascript?
For example I would like to add under General , Turn off alarms, which I need to send a value do an grpip.
Thanks,
Gabe
I've figured it out. For anyone else who needs to do this
1234567891011121314151617181920212223242526
document.addEventListener('DOMContentLoaded', function() {         var container = document.querySelector('.sidebar');         var ul = container.querySelector('ul');         var li = document.createElement("li");         var span = document.createElement("span");         span.classList.add('a');               var link = document.createElement("a");         link.href = "#";          link.textContent = "Nuevo Link";                  span.appendChild(link);           li.addEventListener('click', HaceClick);         li.classList.add('level-1');         li.appendChild(span);                 var referenceNode = ul.getElementsByTagName("li")[3]; // Insert before 3rd in the list         ul.insertBefore(li, referenceNode);      }); function HaceClick() {         alert('Ha pulsado Nuevo Link!');           }
It will appear in the left sidebar menu
