UDP to Ecler
Hi Admin,
I have connection to a Ecler Matrix, the connection is there, but on UDP receive i get multiple answers but i have no cleu how to get them until the full response is ready, do you have a solution?
client:sendto("SYSTEM CONNECT\n\r", '192.168.1.246', 5800)     result = client:receive()     log(result)     result = client:receive()     log(result)     result = client:receive()     log(result)     result = client:receive()     log(result)     result = client:receive()     log(result)
Each receive gives me the next reponse line, but i want them all until it's done with one receive call...
Each receive() call returns a single UDP message. You should call receive in a loop until the ending message is received. If that's not possible then set socket timeout to detect when no messages are left to receive.
Already done that but i thought that was not “clean”, thanks for confirming this is the way to go..
