HomeLYnk keep restarting
Hello Dears,
I have a HomeLYnk in an old site, I try to take a backup but it failed donload several times, I notice the LED of the device turn off and on again, seems that the device restart continouslly every several minutes.
could this issue be solved be a new FW or SDcard Flash?
Best Regards,
It is most likely some programming issue. Stop all scripts and see it it helped. What is the CPU/Memory/Disk info?
(10.09.2025, 07:08)Daniel Wrote: It is most likely some programming issue. Stop all scripts and see it it helped. What is the CPU/Memory/Disk info?
there is no script at all!
but the device around 13 years old
CPU/Memory/Disk info are normalĀ
the device is lightly used
Best Regards,
If it is that old it could be anything, I would probably start from replacing the SD card. Run it with an empty project, if same will happen then something is damaged on the hardware.
