I don't know how it is connected with LM, but certainly is in some way or other.
Everywhere I install a LM, I use it for connecting to the KNX bus. In most cases I also use it in combination with mikrotik router (via VPN) to make changes or even remote programming a whole site (yes, it is possible, and yes, it is painful).
In some places the programming can be difficult with devices that need a lot of stuff to download, sometimes impossible. It is not directly connected to the method I connect to the LM, I've tried via LAN, WIFI, VPN and it is always the same problem with the same devices. Only direct bus connection with USB interface or with my old trusty Siemens IP router can make it to work. In the same time the installation is ok, with the standard green KNX cable, the voltages are ok, and the power supply is never fully loaded (usually around 60-70% then I add another line).
Any ideas where to search for a problem?
br, Z
Edit:
Admin, I made an error in the poll, please change the last option No! to Yes!
br, Z
Edit:
