Reboot Chromecast
I'm struggling with controlling a Chromecast from LM. I'm using  this script provided by Erwin:
-- ****** Control Chromecast with 1 byte object version 1.0 created by Erwin van der Zwart ******* --
-- **************************************** SET PARAMETERS *************************************** --
-- Chromecast IP address
ip_chromecast = '192.168.10.23'
-- Additional info from browser about
-- http://192.168.10.23:8008/ssdp/device-desc.xml
-- http://192.168.10.23:8008/setup/scan_results
-- http://192.168.10.23:8008/setup/eureka_info?options=detail
-- http://192.168.10.23:8008/setup/supported_timezones
-- http://geeknizer.com/how-chromecast-works-chromecast-protocol-explained/
value = event.getvalue()
require 'socket.http'
function control_chromecast(uri, request)
 local request_body = request
 local response_body = { }
 local res, code, response_headers = socket.http.request
   url = "http://" .. ip_chromecast .. ":8008/" .. uri;
   method = "POST";
   headers =
     ["Content-Type"] = "application/x-www-form-urlencoded";
     ["Content-Length"] = #request_body;
   source = ltn12.source.string(request_body);
   sink = ltn12.sink.table(response_body);
 return res, code, response_headers
-- Action on value 1
if value == 1 then
    -- Start Youtube video
    res, code, response_headers = control_chromecast('apps/YouTube', [[v=_iuBO1lkch8]])
-- Action on value 2
if value == 2 then
    -- Stop Youtube video
    res, code, response_headers = control_chromecast('apps/YouTube', [[DELETE]])
-- Action on value 3
if value == 3 then
    -- Start Chromecast Homescreen
    res, code, response_headers = control_chromecast('apps/ChromeCast', [[]])
-- Log results
resulthandling = false
if resulthandling == true then
 -- Handler for results
 log("Status:", res and "OK" or "FAILED")
 log("HTTP code:", code)
 log("Response headers:")
 if type(response_headers) == "table" then
   for k, v in pairs(response_headers) do
     log(k, ":", v)
   -- Would be nil, if there is an error
   log("Not a table:", type(response_headers))
 log("Response body:")
 if type(response_body) == "table" then
   log(table.concat(response_body))
Action value 1 and 2 does work. Value 3 gives an error 404 on the tv screen.
From my windows command line I can reboot the chromecast by doing this:
curl -Lv -H Content-Type:application/json http://192.168.22.99:8008/setup/reboot  -d "{""params"":""now""}"
and start youtube with this:
curl -Lv -H Content-Type:application/json http://192.168.22.99:8008/apps/YouTube -d v=_iuBO1lkch8
I would like to do a reboot and get the homescreen/screensaver running from the LM.
I've added:
-- Action on value 4
if value == 4 then
 -- Reboot Chromecast
 res, code, response_headers = control_chromecast('setup/reboot', [[{params=now}]] )
But the response is 400 bad request (from Wireshark). I've tried changing the parameters to "{""params"":""now""}", [["{""params"":""now""}" ]] and all possible variations in between. I'm out of clue.
Would anyone help me?
Best regards
Bjorn
I just needed to post here before I saw what I had to do:
This script reboots the Chromecast:
require'socket.http'
response_body = {}
request_body = [[{"params":"now"}]]
socket.http.request{
 url = "http://192.168.22.99:8008/setup/reboot";
   method = "POST";
   headers = {
   ["Content-Type"] = "application/json";
        ["Content-Length"] = string.len(request_body)
I still cant force the screensaver back though.
