Event Script problem
Hi I have make some event script "parametric" , in one sysstem with more event alarm
see below
-- GET CURRENT DATA AS TABLE
now = os.date('*t')
TS=' del '..now.day..'/'..now.month..'/'..now.year..' alle '..now.hour..':'..now.min..':'..now.sec..'.'
-- GET MAIL ADDRESS
Dest  = grp.getvalue('32/1/41')
--GET ADDRESS EVENT FIRE
id=event.dst
--GET VALUE
value =grp.find(event.dst).value
-- GET NAME OF OBJECT
name = grp.alias(id)
if (value == true) then
  subject = 'Allarme Scatto'
  message = 'Inizio ' .. 'ID ' .. id .. ' - ' .. name  ..' '.. TS
  mail(Dest, subject, message)
  alert(message)
  ALM = 1
elseif (value == false) then
  subject = 'Ripristino Allarme'
  message = 'Ripristino ' .. 'ID ' .. id .. ' - ' .. name  ..' ' .. TS
  ALM = 0
--SET TOTAL NUMBER ALARM
ALM_OLD = grp.getvalue('32/1/40')
if (ALM==1) then
  Alm_N = ALM_OLD+1
elseif (ALM==0) then
  Alm_N = ALM_OLD-1
grp.write('32/1/40', Alm_N)
My proble the script when have event not run , manualy run , where is the problem ?
Best regards
Hi!
Does your trigger variable has been changed?
Does your triger variable has boolean datatype? (01.002 boolean)
Put some logs in your script and try to modify event group address manually. Try this:
-- GET CURRENT DATA AS TABLE now = os.date('*t') TS=' del '..now.day..'/'..now.month..'/'..now.year..' alle '..now.hour..':'..now.min..':'..now.sec..'.' -- GET MAIL ADDRESS Dest  = grp.getvalue('32/1/41') --GET ADDRESS EVENT FIRE id=event.dst --GET VALUE value =grp.find(event.dst).value -- GET NAME OF OBJECT name = grp.alias(id) log(value) ------------------------------------------------------------------------------------- if (value == true or value == 1) then   log('value is true')   subject = 'Allarme Scatto'   message = 'Inizio ' .. 'ID ' .. id .. ' - ' .. name  ..' '.. TS   mail(Dest, subject, message)   alert(message)   ALM = 1 elseif (value == false or value == 0) then   log('value is false')   subject = 'Ripristino Allarme'   message = 'Ripristino ' .. 'ID ' .. id .. ' - ' .. name  ..' ' .. TS   mail(Dest, subject, message)   ALM = 0 end ------------------------------------------------------------------------------------ --SET TOTAL NUMBER ALARM ALM_OLD = grp.getvalue('32/1/40') if (ALM==1) then   Alm_N = ALM_OLD+1 elseif (ALM==0) then   Alm_N = ALM_OLD-1 end grp.write('32/1/40', Alm_N)
(31.07.2020, 08:47)fleeceable Wrote: Hi!
Hi the variable is boolean , I make script event on object page .
I have more of 100 event script , is possible the problem is this ?
thank's
Tested your script and works for me.
At least when I modified object value from objects tab.
What is your processor values?
Admins can answer that if script count can be the problem...
Have you tried a restart of the controller?
(31.07.2020, 10:29)Erwin van der Zwart Wrote: Hi,
Yes controller restarted , the mail address
is set in init script.
thank for all
