Slider for dim lights java
Does anyone know a code to write 4bit to localbus.lp with a slider in javascript?
4-bit is not a slider but start/stop dimming. Usually only 3 values are used: 9 = up 100%, 1 = down 100%, 0 = stop.
For 1-byte dimmer slider you need to use HTML input range element: https://developer.mozilla.org/en-US/docs...nput/range
(18.05.2021, 05:41)admin Wrote: 4-bit is not a slider but start/stop dimming. Usually only 3 values are used: 9 = up 100%, 1 = down 100%, 0 = stop.
Ok, thank you Smile
