07.06.2021, 12:48
we want to reload a page by triggering a KNX object in Wiser for KNX, we reused a javascript that works fine on every device (so the code is fine) but in this case it doesn't work.
Javascript console has this warning:
DevTools failed to load source map: Could not load content for http://192.168.178.8/scada/resources/min...min.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
we have a VPN and everything seems to work fine on that side, any ideas?
Thank you for your help.
We found the problem,
our bad, but thank you for your help.
