How can I customize the software interfaces via CSS with my logo and my colors?
Customize the visualization
08.03.2016, 18:31
You can edit visualization CSS in Vis. graphics -> Edit custom CSS. Main Logic Machine interface and System Config cannot be customized.
13.07.2016, 13:38
If I understand correctly, for trend and schedulers, we cannot change the text by translation?
13.07.2016, 18:47
(This post was last modified: 13.07.2016, 19:00 by Erwin van der Zwart.)
Hi Severian,
You can't change text with css, css is designed only for setting properties. The language of trends and schedulers are following the selected language that can be set in general config. If your language is not available you have a challenge (: BR, Erwin |
