22.08.2022, 06:32
(This post was last modified: 22.08.2022, 07:58 by pioneersteffen.)
Hi @all,
I working on a script to calculate the solar energy through the windows based on Solcast API. Therefore I defining the window parameters as tables and want to calculate the energy forecast for each window and write them to a new table (fe) for the window index.
Unfortutately this writing to the table is not working, logs attached.
Can you please help me what I'm doing wrong?
Many thanks for your help!
Best Regards
Steffen
Best Regards
Steffen
12345678910111213141516171819202122232425262728293031323334353637383940414243444546474849505152535455565758596061626364656667686970717273747576777879808182838485868788899091
require('json')
https = require 'ssl.https'
appid = 'xxx'
lat = '52'
lon ='10'
azi = '170'
hours = '48'
format = 'json'
url = 'https://api.solcast.com.au/world_radiation/forecasts?latitude=%s&longitude=%s&hours=%s&format=%s&api_key=%s'
url = string.format(url, lat, lon, hours, format, appid)
res, code, headers, status = ssl.https.request(url)
log (code, status, headers)
data = json.pdecode(res)
--Fault messages:
if not data then
alert('Error converting data')
return
if not res then
alert('Error collecting data')
return
data = data.forecasts
gwert=0.5
ff={} --Tabelle Fensterfläche
fw={} -- Tabelle Fenster Winkel
fn={} -- Tabelle Fenster Neigung, Senkrecht = 90
fe={} --Fensterenergemenge aus f_energiesum
--Galerie
ff[2]=1.6 -- Glasfläche Fenster
fw[2]=8 -- Azimuth Fenster zu Süden = 0° ; Westen = + 90°
fn[2]=33 -- Neigung Senkrecht = 90
--Leben
ff[3]=2.1 -- Glasfläche Fenster
fw[3]=8 -- Azimuth Fenster zu Süden = 0° ; Westen = + 90°
fn[3]=90 -- Neigung Senkrecht = 90
ff[4]=7.45 -- Glasfläche Fenster
fw[4]=8 -- Azimuth Fenster zu Süden = 0° ; Westen = + 90°
fn[4]=90 -- Neigung Senkrecht = 90
ff[5]=2.63 -- Glasfläche Fenster
fw[5]=-82 -- Azimuth Fenster zu Süden = 0° ; Westen = + 90°
fn[5]=90 -- Neigung Senkrecht = 90
now = os.date('*t')
hour = now.hour
i=1 --Index halbe Stunde aus Solcast json
f=2 --Fensterindex Tabelle
f_energiesum = 0
rest_hour = 24 - hour
for f=2,5,1 do --EDIT Anpassung Fensteranzahl
while i<3 do
dni = data[i].dni
ghi = data[i].ghi --global horizontal
dhi = data[i].dhi --diffus horizontal
bh = ghi - dhi --direkt horrizontal
zenith = data[i].zenith
sunh = 90 - zenith -- Sonnenhöhe
azimuth = data[i].azimuth
w_einstrahl = math.asin(math.sin(math.rad(sunh)) * math.cos(math.rad(fn[f])) + math.cos(math.rad(sunh))*math.cos(math.rad(fw[f]-azimuth))*math.sin(math.rad(fn[f])))
dir_einstrahl = math.sin(w_einstrahl)/math.sin(math.rad(sunh))*bh --Direktstrahlung auf eine geneigte Oberfläche
if sunh == 0 then dir_einstrahl = 0 end -- Abfangen Division durch 0
dif_einstrahl = (1 + math.cos(math.rad(fn[f])))/2*dhi --diffuse Horizontalstrahlung
f_energie = (dir_einstrahl + dif_einstrahl)*ff[f]*gwert
f_energiesum = f_energiesum + f_energie
fe[f] = f_energiesum
-- log(i,f, ghi, dhi, bh, sunh, azimuth, w_einstrahl, dir_einstrahl, dif_einstrahl, f_energie, f_energiesum, ff[f], fw[f], fe[f])
i=i+1
grp.write('49/'..f..'/8', f_energiesum)
log(f,fw,ff,fn,fe)
endCode:
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100101102103104105106107108109110111112113114115116117118119120121122123124125126127128129130131132133134135136137138139140141142143144145146147148
Solcast_Radiation 22.08.2022 08:27:09
* arg: 1
* number: 2
* arg: 2
* table:
[2]
* number: 8
[3]
* number: 8
[4]
* number: 8
[5]
* number: -82
* arg: 3
* table:
[2]
* number: 1.6
[3]
* number: 2.1
[4]
* number: 7.45
[5]
* number: 2.63
* arg: 4
* table:
[2]
* number: 33
[3]
* number: 90
[4]
* number: 90
[5]
* number: 90
* arg: 5
* table:
[2]
* number: 280.824289622413
* arg: 1
* number: 3
* arg: 2
* table:
[2]
* number: 8
[3]
* number: 8
[4]
* number: 8
[5]
* number: -82
* arg: 3
* table:
[2]
* number: 1.6
[3]
* number: 2.1
[4]
* number: 7.45
[5]
* number: 2.63
* arg: 4
* table:
[2]
* number: 33
[3]
* number: 90
[4]
* number: 90
[5]
* number: 90
* arg: 5
* table:
[2]
* arg: 1
* number: 4
* arg: 2
* table:
[2]
* number: 8
[3]
* number: 8
[4]
* number: 8
[5]
* number: -82
* arg: 3
* table:
[2]
* number: 1.6
[3]
* number: 2.1
[4]
* number: 7.45
[5]
* number: 2.63
* arg: 4
* table:
[2]
* number: 33
[3]
* number: 90
[4]
* number: 90
[5]
* number: 90
* arg: 5
* table:
[2]
* arg: 1
* number: 5
* arg: 2
* table:
[2]
* number: 8
[3]
* number: 8
[4]
* number: 8
[5]
* number: -82
* arg: 3
* table:
[2]
* number: 1.6
[3]
* number: 2.1
[4]
* number: 7.45
[5]
* number: 2.63
* arg: 4
* table:
[2]
* number: 33
[3]
* number: 90
[4]
* number: 90
[5]
* number: 90
* arg: 5
* table:
[2]
