02.10.2015, 14:38
I am having a little problem with the Objects tab in the logic machine. This tab shows a list of group addresses but the list is only populated when auto update is enabled. I have tried importing an ESF file through Utilities but the Objects tab remains empty until auto update starts working. Also, whenever the browser is closed and then opened again later to access the Objects tab, every group address that was found earlier is gone and requires auto update to show them again.
Is this how this is supposed to work? I was under the impression that when ESF files were imported that all the group addresses would be instantly visible in the Objects tab. Is there a way to see all the group addresses instantly within the logic machine that have been manually created or imported without the need to sniff for them first?
