16.01.2017, 09:55
Hi, i cannot create any file per ftp on my LM3 only reading is possible.
Is there any solution for this problem?
FTP Access
16.01.2017, 09:55
Is there any solution for this problem? Thanks
16.01.2017, 10:33
For generic files you should use ftp username. When using apps username, you cannot upload into base directory.
16.01.2017, 10:45
It might work in different version, but still you should use ftp username.
With FW 20160714 it also doesn't work
why is the authorization is differently? 26.PNG is the LM without full access
10.01.2023, 10:07
Hi.
Well i'm stupid. Please tell me how to get access to ftp. I would like to upload file to \user If im connecting to ftp by FileZilla (user name: FTP, pass: (i put pass in systemConfig/Services/FTP server) i can get access to catalog \ but is nothing there. What im doing wrong?
10.01.2023, 10:20
Use apps username to access user directory.
10.01.2023, 10:27
10.01.2023, 10:27
There's no default password, you have to set it in System config.
10.01.2023, 10:28
15.04.2023, 18:37
Hello
When i login with user ftp is don't see any directory, only a empty root. When i login with user apps, i see al the directory's like public, cron,... but i can't upload anything to this directory? What do i wrong? I got a Wiser device. Many thanks!
17.04.2023, 07:46
What are you trying to upload and to which location exactly?
19.04.2023, 07:23
I want to upload my own created html page created with Chart.js.
19.04.2023, 07:35
Then you should be able to upload it to user directory, is this what you tried?
Ctrl+F5 |
