Z-buffer
I've two interferring objects in my visu. Can I set "Bring to top" and "Send to bottom"? Or is there any other trick how to move an object to background? CSS?
Thank you in advance.
Give your elements a custom class like ontop and onbottom and use this as custom css:
.ontop {    z-index: 80 !important; } .onbottom {     z-index: 60 !important; }
Depending on the original z-index of the elements, you might need to change the 60 and 80 value
Thank you it works!
