Export objects / GA
Hi @all,
is there any way to export all objects/ GA in a file type that can we reimported later on?
I need to roll back to a month old controller backup and in the meantime I created many new virtual objects and I need to import them after roll back.
Many thanks for your help.
Best regards
Steffen
Install LM Sync app.
Many thanks for the quick reply. Are there any other options? I have no internet access onside to connect to App Store.
Old fashion script (:
--Export to FTP objects_table = db:getall('SELECT * FROM objects') jsonstring = require('json').encode(objects_table) io.writefile('/www/user/objects.txt', jsonstring) script.disable(_SCRIPTNAME)
Copy objects.txt from Apps FTP user folder to your other controller
--Import from FTP objectstring = io.readfile('/www/user/objects.txt') newobjects_table = require('json').pdecode(objectstring) for _, object in ipairs(newobjects_table) do   exist = grp.alias(object.name)   if exist == nil then     objectaddress = knxlib.decodega(object.address)     grp.create({       address = objectaddress,       name = object.name,       datatype = object.datatype,       comment = object.comment,       units = object.units,       tags = object.tagcache,       enums = object.enums,       visparams = object.visparams,     })   end end script.disable(_SCRIPTNAME)
Many thanks for the brilliant help as always!
