Add a listener when a widget closes
is there a way to detect, via javascript, when a widget closes?
Thanks!
Not directly, but as a work-around you can create a timer which checks widget state each second:
var widget = $('#widget-1'), visible = false; setInterval(function() {   var state = widget.is(':visible');   if (state != visible) {     visible = state;     console.log('widget visibility state', visible);   } }, 1000);
Than you, it works! Smile
