Connect N4AIA08 to LogicMachine
I have a Modbus analog input device, which I would like to connect to my LogicMachine.
I managed to connect to that device with my laptop and read the inputs.
I also created the .json file, which I think it is correct.
Any help on how to connect to my LogicMachine and read the inputs?
Please keep in mind that this is the first time I work with Modbus,
so there are a lot I still need to learn.
.pdf   N4AIA08 N4AIB16 N4AIC24 Manual.pdf (Size: 619.72 KB / Downloads: 12)
.pdf   N4AIA08 N4AIB16 N4AIC24 MODBUS RTU Commamd.pdf (Size: 352.69 KB / Downloads: 8)
.json   N4AIA08 v20250327.json (Size: 1.37 KB / Downloads: 9)
Connect it to LM, set RTU settings and then use Read test and check if you can read the values. Drop screenshot of correct configuration.
(28.03.2025, 08:28)Daniel Wrote: Connect it to LM, set RTU settings and then use Read test and check if you can read the values.  Drop screenshot of correct configuration.
I managed to make it work just fine. Thank you.
