Remote access for multiple users on a single LogicMachine
I have a question regarding remote access for multiple users.
I have an apartment building with a single LogicMachine installed.
For each apartment I need to create a simple control interface in Mosaic or a custom solution in the Old Visualization — the client hasn’t decided yet. There is only one LM, but 10 apartments, and each apartment must have its own remote access.
Is it possible to add multiple LM Cloud accounts to one LM?
Or is the only option to create standard local users and provide remote access through VPN or Zerotier?
Thanks in advance!
BG
Account in the cloud app is Admin which should be you, later you can create as many normal users and each of them will have restricted access to his apartments. Nothing special has to be done. I would recommend to use advanced user access features and restrict the group addresses for extra security.
Visu is the go for solution. Old visualisation has no cloud access.
(27.08.2026, 10:05)Daniel Wrote: Account in the cloud app is Admin which should be you, later you can create as many normal users and each of them will have restricted access to his apartments. Nothing special has to be done. I would recommend to use advanced user access features and restrict the group addresses for extra security.
I still don’t understand how this is supposed to work. :/
When I enter the login credentials in the LM Home app, it immediately logs me into the Admin account.
During login I enter the email and password for LM Cloud. So how am I supposed to log in as a specific normal user instead of always ending up in the Admin profile?
This also raises another question: when creating a user, there is a field called “Cloud login (e-mail)”. What is the purpose of this field?
I cant create several Users with same  Cloud login (e-mail).
You always will be admin, other users must create his own cloud account here https://remote.logicmachine.net/user and his email should be used in his user access settings.
You can't use same email for all users Smile
(27.08.2026, 12:10)Daniel Wrote: You always will be admin, other users must create his own cloud account here https://remote.logicmachine.net/user  and his email should be used in his user access settings.
Ok, now I understand, thank you.
Does this mean that the only thing that matters is the Cloud login (e‑mail) field, and I simply enter the user’s LM Cloud email there?
So there is no need to create a “New network” or paste any connection string for each user?
Here is what I did:
  • I created a new LM Cloud account for User 1.
  • I created a user in LM and in the Cloud login (e‑mail) field I entered the LM Cloud email of User 1.
  • Then I tried logging into LM Home using that LM Cloud account.
The problem is:
I don’t see my Mosaic configuration. I only see the changed background, but there are no widgets, no rooms, no floors visible.
Did I miss something in the configuration?
Yes, connection string is only needed once for admin and then rest is managed by our cloud guest accounts.
User must have a permissions set and always do Cloud app sync after any changes.
(27.08.2026, 12:36)Daniel Wrote: Yes, connection string is only needed once for admin and then rest is managed by our cloud guest accounts.
It works.
Thank You!
Not the same, but maybe the same.
I have now access to two LM5's on my cloud account. How can I swap between them as I want in the link https://remote.logicmachine.net/settings?
I also miss the possibility to choose what LM5 I want to connect in the LM Home android app.
In cloud each application has its own place where the network are switched, In Visu it is in the menu on the bottom, other apps on the header on the right.
On local access the default homepage is defined under user access for each user.
I don't understand, in this picture, how do the user choose what LM5 to connect?
In the Visu menu.
Answering your next question, Set menu to toggle in general settings so it will be just a round circle.
Remember to sync cloud
