Passage from one HK/LM to another
I would like to know if there is a simple way to switch from viewing one HomeLynk / LM to another without nesting the visualization of the other but really opening up the visualization of the second HK / LM.
Use this as custom javascript on object bit 1/1/1 in both controllers:
$(function() {
     grp.listen('1/1/1', function(object, state) {
         var value = object.value;
         if (state == 'value') {
            if (value == 0) {
              $(location).attr('href', 'http://admin:admin@192.168.0.10/scada-vis');
            } else {
              $(location).attr('href', 'http://admin:admin@192.168.0.11/scada-vis');
      }, true);
Make sure both controllers have this custom javascript, the object 1/1/1 and can communicate over KNX IP or KNX TP so object value will be always the same in both controllers
Hi Erwin,
Very good.
