Threads: 161
05.10.2018, 20:27
(This post was last modified: 05.10.2018, 20:35 by buuuudzik .)
My client has on his house HIKVision cameras and I am so impressed about its quality and also modern webserver and API. But it is fresh software so I must update my scripts to support such cameras. I found that I cannot download an image in same way as before in BCS cameras. I have right path:
http://username :password@ip_address:port/ISAPI/Streaming/channels/102/picture
and it's work perfectly on webbrowser but unfortunately not in script.
This is my script:
require (
'socket.http' )
local image1 =
socket.http.request (
'http://username:password@ip_address:port/ISAPI/Streaming/channels/102/picture' )
log (#
image1 )
And it logs that length of image1 is nil.
I've found this specification:
http://down.dipol.com.pl/Cctv/-Hikvision...ervice.pdf
I've had similar differences when I've tried get image from old BCS camera and new HIK by Postman app and I've figured out that on HIK cameras autentification must be set to Digest Auth. How can I do it in Lua?
Done is better than perfect
Threads: 161
05.10.2018, 21:41
(This post was last modified: 05.10.2018, 21:47 by buuuudzik .)
Also I see that there is possibility to download uptodate list or have connection with camera and get notified when new event occured but it is not so easy to me. In node js all would be easy but how use this function in Lua?
http://www.ragingcomputer.com/2016/06/hi...ng-node-js
Perfect would if admin could give some short start guide how get the data(without parsing) like in nodejs:
https://github.com/ragingcomputer/node-h...kvision.js
Threads: 43
Threads: 161
06.10.2018, 06:19
(This post was last modified: 06.10.2018, 06:19 by buuuudzik .)
(06.10.2018, 05:01) admin Wrote: Try code for digest auth in this post: https://forum.logicmachine.net/showthrea...64#pid9364
It works in local with http. I see that the library is not a 4 line code
And what do you think admin about this alertStream?
I think this could be a very good option to integrate e.g. linedetection or facedetection from so sharp camera.
Threads: 43
Try this for alert stream:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
socket =
require (
'socket' )
mime =
require (
'mime' )
host =
'192.168.1.2'
port =
80
auth =
'user:password'
init =
'GET /ISAPI/Event/notification/alertStream HTTP/1.1\r\n' ..
'Host: ' ..
host ..
port ..
'\r\n' ..
'Authorization: Basic ' ..
mime.b64 (
auth ) ..
'\r\n' ..
'Accept: multipart/x-mixed-replace\r\n\r\n'
sock =
socket.tcp ()
sock :
settimeout (
60 )
res ,
err =
sock :
connect (
host ,
port )
if res then
alert (
'connection ok' )
sock :
send (
init )
line ,
err =
sock :
receive (
'*l' )
log (
line ,
err )
alert (
'connection failed: ' ..
tostring (
err ))
Threads: 161
Today I will check for sure. Very thanks and this is really nice feature
Threads: 161
I have the info that module socket.mime not found
Threads: 43
Replace it with require('mime')
Threads: 161
This script should be in resident 0s? Now I have it in resident 10s and updated version returns in Alerts "connection failed: nil"
Threads: 43
I've updated the script, try again. Use a resident script with sleep time more than zero for testing, otherwise you might get too many alerts/logs.
Threads: 161
Now is unauthorized message:
arg :
string :
HTTP /
1.1 401 Unauthorized
arg :
nil
I'm sure I have right credentials
Threads: 43
Replace *l with *a and post the whole output.
Threads: 161
Below whole result:
arg :
string :
HTTP /
Date :
Tue ,
09 Oct 2018 19 :
29 :
04 GMT
Server :
App-webs /
Content-Length :
178
Content-Type :
text /
html
Connection :
close
WWW-Authenticate :
Digest qop =
"auth" ,
realm =
"IP Camera(13656)" ,
nonce =
"4e3245794d444a684f6a56684e47526b5a575179" ,
stale =
"FALSE"
DOCTYPE html >
html ><
head ><
title >
Document Error :
Unauthorized </
title ></
head >
body ><
h2 >
Access Error :
401
p >
Authentication Error </
p >
body >
html >
arg :
nil
Threads: 43
This means that you need to use digest auth here as well. Considering the code complexity, writing any examples without access to the real device is like shooting in the dark, sorry.
Threads: 161
(10.10.2018, 10:22) admin Wrote: This means that you need to use digest auth here as well. Considering the code complexity, writing any examples without access to the real device is like shooting in the dark, sorry.
Thanks for your efforts. I can give you an access to the real device via private message.
Threads: 43
Try this, change IP, port, user and pass as needed. If this works correctly, you should get xml payloads in Logs tab, otherwise errors will go to Alerts tab.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136
require (
'socket' )
md5sum =
require (
'encdec' ).
md5
host =
'192.168.1.2'
port =
80
user =
'username'
pass =
'password'
uri =
'/ISAPI/Event/notification/alertStream'
function getheader (
resp ,
header )
local st ,
en
header =
header ..
st =
resp :
find (
header )
if st then
en =
resp :
find (
st + #
header )
if en then
return resp :
sub (
st + #
header ,
en -
1 )
function makedigestheader (
headers )
local digest = {}
for _ ,
header in ipairs (
headers )
do
if not header.unquote then
header [
2 ] =
header [
2 ] ..
digest [ #
digest +
1 ] =
header [
1 ] ..
header [
2 ]
return 'Digest ' ..
table.concat (
digest ,
function hash (...)
return md5sum (
table.concat ({...},
init = {
'GET ' ..
uri ..
' HTTP/1.1' ,
'Host: ' ..
host ,
'Accept: multipart/x-mixed-replace' ,
sock =
socket.tcp ()
sock :
settimeout (
60 )
res ,
err =
sock :
connect (
host ,
port )
if not res then
alert (
'init connection failed: ' ..
tostring (
err ))
return
sock :
send (
table.concat (
init ,
'\r\n' ) ..
'\r\n\r\n' )
resp ,
err =
sock :
receive (
'*a' )
sock :
close ()
if not resp then
alert (
'no response: ' ..
tostring (
err ))
return
realm =
getheader (
resp ,
'realm' )
nonce =
getheader (
resp ,
'nonce' )
if not realm or not nonce then
alert (
'no realm/nonce' )
return
nc =
'00000001'
cnonce =
string.format (
'%08x' ,
os.time ())
method =
'GET'
response =
hash (
hash (
user ,
realm ,
pass ),
nonce ,
nc ,
cnonce ,
'auth' ,
hash (
method ,
uri )
auth = {
'username' ,
user },
'realm' ,
realm },
'nonce' ,
nonce },
'uri' ,
uri },
'cnonce' ,
cnonce },
'nc' ,
nc ,
unquote =
true },
'qop' ,
'auth' },
'algorithm' ,
'MD5' },
'response' ,
response },
table.insert (
init ,
2 ,
'Authorization: ' ..
makedigestheader (
auth ))
sock =
socket.tcp ()
sock :
settimeout (
60 )
res ,
err =
sock :
connect (
host ,
port )
if not res then
alert (
'data connection failed: ' ..
tostring (
err ))
return
sock :
send (
table.concat (
init ,
'\r\n' ) ..
'\r\n\r\n' )
cl =
'Content-Length:'
while true do
line ,
err =
sock :
receive (
'*l' )
if line then
if line :
find (
cl ,
1 ,
true )
then
len =
tonumber (
line :
sub (#
cl +
1 ))
if len then
sock :
receive (
'*l' )
data ,
err =
sock :
receive (
len )
if data then
log (
data )
alert (
'data receive failed: ' ..
tostring (
err ))
alert (
'line receive failed: ' ..
tostring (
err ))
break
sock :
close ()
Threads: 161
It works I see such output:
string : <
EventNotificationAlert version =
"2.0" xmlns =
"http://www.hikvision.com/ver20/XMLSchema" >
ipAddress >
192.168.101.201 </
ipAddress >
portNo >
80 </
portNo >
protocol >
HTTP </
protocol >
macAddress >
aa :
bb :
cc :
dd :
ee :
ff </
macAddress >
channelID >
1 </
channelID >
dateTime >
2018 -
10 -
10T14 :
31 :
43 +
01 :
00 </
dateTime >
activePostCount >
0 </
activePostCount >
eventType >
videoloss </
eventType >
eventState >
inactive </
eventState >
eventDescription >
videoloss alarm </
eventDescription >
channelName >
K03 Podjazd </
channelName >
EventNotificationAlert >
I will find how to parse it. Thank you very much, you are very wise
Threads: 9
28.05.2020, 14:40
(This post was last modified: 28.05.2020, 14:45 by Alberto.ricof .)
I rescue this thread to see if anyone can help me,
How can I find the values in the XML data that the string returns? specifically what I need are the ones marked in yellow in the attached screenshot. These records are only sent if: <statisticalMethods> realTime </statisticalMethods>
Thank you very much in advance !!
Best regards
Threads: 6
You need to parse the XML data to get values from it, you can use the build in LuaExpat lib for that.
See this post for a sample how to use the lpx parser:
https://forum.logicmachine.net/showthrea...2#pid11472
Threads: 9
(28.05.2020, 21:16) Erwin van der Zwart Wrote: Hi,
See this post for a sample how to use the lpx parser: https://forum.logicmachine.net/showthrea...2#pid11472
Thank you very much Erwin, it's just what i needed.
Alberto R.
