Hello
My LM randomly crashes. It happens once in five days. Can I investigate what's wrong?
Pictures containing logs attached. Every "System Start" is a LM crash.
What represent these three numbers right to CPU/IO? Are they user/kernel/IO? Can I check why the middle number is so high?
Thank you
One of possible reboot reasons can be out-of-memory condition. This can be caused by too many resident scripts running in parallel and/or loops in event scripts. You can see all running processes in System config.
22.10.2018, 11:50 (This post was last modified: 22.10.2018, 11:55 by Thomas.)
Sorry attached logs here. I forgot press "Add Attachment" button.
(22.10.2018, 11:40)admin Wrote: One of possible reboot reasons can be out-of-memory condition. This can be caused by too many resident scripts running in parallel and/or loops in event scripts. You can see all running processes in System config.
I've 10 resident scripts running. You're right, there could be an infinity loop. Can I discover it somehow? Like logging to a different computer through rsyslog etc?
I turned on "Remote diagnostics" on my LM. Can I connect through SSH to the LM? I tried my admin password, communication password, a regular user but with no luck.
I think one of possible reason for LM crashing is the webserver consuming big portion of the memory. Do you have any suggestion how to lower this number? Can I switch on more aggressive caching at clients?
Thank you
I don't know because LM doesn't show active clients. My guess is something between 100-200.
I've found that LM stop crashing after I stop using remote.
(25.10.2018, 10:02)admin Wrote: Do you mean cloud access or remote http services?
It can be just coincidence but since I turned remote requests off my LM is still on with no interruption. Unfortunately the issue is hardly reproducible because it happens once or twice a day.
Remote HTTP access (object set as "export", Remote service Enabled)
I use this service for data exchange between our attendance system and KNX.
The attendance system simply sends update request when doors are opened/closed.
Use attached .lp file to show a list of connected clients. Upload it to user directory via ftp (apps username), then access it via http://LM_IP/user/clients.lp
Also, please upload your backup somewhere and send via PM so I can test remote access time.
(25.10.2018, 13:55)admin Wrote: Use attached .lp file to show a list of connected clients. Upload it to user directory via ftp (apps username), then access it via http://LM_IP/user/clients.lp
Thank you. Check your PM
