Bug in tag based script
Hello
I think I've found a bug in tag script processing. The script is not processed until I reopen and save tag script.
Steps:
1. Create new (this is important) event based script called bug_test for tag bug_test. Set it active and "Execute on group read". Click "Save".
2. Open Editor and insert code
log('bug test')
3. Choose a random object with datatype 01.1 bit and set tag bug_test to this object
4. From ETS read this object
5. look at the log and you see nothing. You should see "bug test" message.
6. Click bug_test event then click save.
Repeat step 4
Now everything is OK.
Did you press save in script editor after step 2 ?
(15.11.2018, 15:44)Daniel. Wrote: Did you press save in script editor after step 2 ?
Yes
The bug is related to the actual build. It was ok in 2017.06
Hi Daniel,
Recently i already posted that i noticed this also twice in current version 2.3.0, not checked it further yet but could be something is wrong, please test it (:
Thanks for bug report, we will fix it in next release.
