Links for developing apps not on LM
how can I prepare develop environment with localbus access to LM? What links should I use? What params should I pass to localbus.init()?
Done is better than perfect
See this thread: https://forum.logicmachine.net/showthread.php?tid=525
You don't need to pass any params if running on the same device.
I've tried and there is a problem with authentication, especially on Chrome. On Firefox there is no error in console, there is localbus object but listen method never receive any command.
And also how can I run code after init happen and all values will initially updated?
Here's a small sample app for monitoring using localbus.
localbus does not provide start/load events, but you can override start function before calling init like this:
var start = localbus.start; localbus.start = function(auth) {   console.log('started');   start.call(localbus, auth); };
.zip   monitor.zip (Size: 2.49 KB / Downloads: 49)
(15.02.2019, 08:26)admin Wrote: Here's a small sample app for monitoring using localbus.
Hi admin,
I have tested your sample monitor apps and it works like a charm !
B.R,
Chouaibou.
