http.request more then 1 command in the same session
How to execute more then one http request in the same web sessions?
function openDoor(iLoxxId)
  require('socket.http')
 socket.http.TIMEOUT = 5
  local urlLogin = 'http://'..wl_IP..'/login.cgi?Source=Webpage&Username='..wl_USR..'&Password='..wl_PWD
 local urlAccess = 'http://'..wl_IP..'/setRemoteAccess.cgi?Source=Webpage&LoxxId='..iLoxxId..'&Action=Start'
  wl_login_data = socket.http.request(urlLogin)
  log(wl_login_data)
  wl_access = socket.http.request(urlAccess)
  log(wl_access)
openDoor(19)
I have a request for  login and another request for opening the door. But now i received: 401 Authorization Required
If i execute both statements in the browser it works.
You probably get a response in the first request that you need to add to the headers of the second request.
(18.02.2019, 23:02)Erwin van der Zwart Wrote: Hi,
Maybe, but when i execute this statements in the same browser tab it works, so i think it has nothing todo with headers.
Or how to find this out?
Erwin is correct. Try logging response headers:
url = ...
res, code, hdrs, stat = socket.http.request(url)
log(hdrs)
Logged headers should contain "set-cookie" field which then should be parsed and passed as "cookie" header to next request. This post has a similar example though first request is different since login token is in response JSON body: https://forum.logicmachine.net/showthrea...74#pid5774
(19.02.2019, 08:12)admin Wrote: Erwin is correct. Try logging response headers:
url = ...
log(hdrs)
Thanx admin and Erwin Smile
This it the hdrs output:
* table: [set-cookie] * string: SESSION=23136A000858325C; [content-type] * string: text/plain
So then you just need to pass cookie header to the next request:
url1 = ...
url2 = ...
res, err, hdrs = socket.http.request(url1)
if res then
  tbl = {}
  res, err = socket.http.request({
    url = url2,
    headers = {
      cookie = hdrs['set-cookie']
    sink = ltn12.sink.table(tbl),
  if res then
    resp = table.concat(tbl)
    log(resp)
    alert('request 2 failed: ' .. tostring(err))
  alert('request 1 failed: ' .. tostring(err))
(19.02.2019, 09:16)admin Wrote: So then you just need to pass cookie header to the next request:
url1 = ...
url2 = ...
if res then
 tbl = {}
   url = url2,
   headers = {
 if res then
   log(resp)
Yeah, thanks it works!!
