	Threads: 2
I have managed to get rgb control work with scripting towards the KNX, but still cant find any script to control Tunable white.
Can somebody help me? or is it impossible?
Best regards
Daniel
	Threads: 29
How do you control the light?  Here is script which might help
https://forum.logicmachine.net/showthrea...6#pid11326
------------------------------Ctrl+F5
	Threads: 2
		 (15.03.2019, 12:36)Daniel. Wrote:  HiHow do you control the light?  Here is script which might help
I allready checked on that link, but i cant find anything how to control the "kelvin in the white colour"
hmmm. I have allready got the RGB control to work but that does not include the control of the white colour.
Daniel
	Threads: 29
		And this is what this script meant to do. It takes color temperature from an 2 byte object and converts it to RGB value.
	Threads: 45
		Have a look here: http://rsmck.co.uk/hue
It looks like you can send both brightness and color temperature by a single request, you just need to add a new function to the user library.
 Code: {"ct": 500, "bri": 254}
	Threads: 48
		HUE uses CT, not the other one you are familiar with. It’s a simple conversion. https://forum.logicmachine.net/showthrea...hlight=Hcl
	Threads: 2
		19.03.2019, 08:41
(This post was last modified: 19.03.2019, 08:42 by DanielB.)
		 (15.03.2019, 20:15)FatMax Wrote:  HUE uses CT, not the other one you are familiar with. It’s a simple conversion.
Can you give me an example on how i should put this function in user libraries? and how to set it up in event based?. (Just so i can control Kelvin and brightness from knx)
I still dont understand this conversion thing:-)
Best regards
Daniel
	Threads: 45
		Add to user library: Code: function setBrightnessCT(Light_num,brightness,ct)if brightness == 0 then
 body_msg = '{"on":false}'
 response = sendToLight(lamp_id,body_msg)
 return response
 brightness = math.floor((brightness / 1) + 0.5)
 brightness = math.floor((brightness * 2.54) + 0.5)
 ct = math.floor(1000000 / ct)
 ct = math.min(500, ct)
 ct = math.max(154, ct)
 --HTTP request send
 body_msg = '{"on":true,"bri":'..brightness..',"ct":'..ct..'}'
 return sendToLight(Light_num,body_msg)
You will need to map an event script to both brightness and color temperature values:
 Code: require('user.hue)lamp_id = 123
 bri = grp.getvalue('1/1/1') -- 0..100%
 ct = grp.getvalue('1/1/2') -- 2000K..6500K
 setBrightnessCT(lamp_id, bri, ct)
	Threads: 2
		 (19.03.2019, 09:13)admin Wrote:  Add to user library:
 return response
 --HTTP request send
Thank you very much :-)
Now it works like a charm:-)
Daniel
	Threads: 2
		Last question:-)
 Can anybody help me get feedback for colour temperature for this?
 I use this script today and get values for on/off, brightness and colour for rgb
 -- Set name (Lookup in HUE app under light configuration) and feedback adresses (don't change statevalue, brivalue and colorvalue as they are used as memoryfield)
 addressmapping = {
 -- Name				  -- On/Off FB	   -- Bright FB   -- Color FB
 ['KjkGangstripe'] = {state = '1/5/16', bri = '1/3/20', rgb = '1/7/16', statevalue = '', brivalue = '', colorvalue = ''},
 ['Kjkinnredning'] = {state = '1/5/17', bri = '1/6/17', rgb = '1/7/17', statevalue = '', brivalue = '', colorvalue = ''},
 --  ['Hue color lamp 3'] = {state = '1/3/3', bri = '1/4/3', rgb = '1/5/3', statevalue = '', brivalue = '', colorvalue = ''},
 --  ['Hue color lamp 4'] = {state = '1/3/4', bri = '1/4/4', rgb = '1/5/4', statevalue = '', brivalue = '', colorvalue = ''}
 -- Set polling interval in seconds
 interval = 1
 -- Use logging
 logging = true
 require('user.hue')
 require('json')
 -- loop indefenitly
 while true do
 reply = getHueLights()
 mylamps = json.decode(reply)
 for _, item in pairs(mylamps) do
 -- Check if lamp is found by bridge otherwise it make no sense to send commands
 -- if item.state.reachable == true then
 -- On/Off
 name = addressmapping[item.name]
 if name then
 addr = addressmapping[item.name]['state']
 if addr and addr ~= '' then
 currentvalue = addressmapping[item.name]['statevalue']
 if currentvalue ~= item.state.on then
 grp.update(addr, item.state.on)
 addressmapping[item.name]['statevalue'] = item.state.on
 if logging == true then
 log('lamp ' .. item.name .. ' state is: ' .. tostring(item.state.on))
 -- Brightness
 if name then
 addr = addressmapping[item.name]['bri']
 -- Check if lamp is on otherwise overrule BRI value to 0
 if item.state.on == false then
 item.state.bri = 0
 currentvalue = addressmapping[item.name]['brivalue']
 if currentvalue ~= item.state.bri then
 grp.update(addr, math.floor((tonumber(item.state.bri)/2.55) + 0.5))
 addressmapping[item.name]['brivalue'] = item.state.bri
 log('lamp ' .. item.name .. ' brightness is: ' .. math.floor((tonumber(item.state.bri)/2.55) + 0.5) .. ' %')
 -- Color
 if name then
 addr = addressmapping[item.name]['rgb']
 -- Check if lamp is on otherwise overrule color value to 0
 colorvalue = 0
 if item.state.colormode == 'xy' then
 currentvalue = addressmapping[item.name]['colorvalue']
 colorvalue = xy_to_rgb(item.state.xy[1],item.state.xy[2],item.state.bri)
 --colorvalue = xyz_to_rgb((item.state.xy[1] * 100), (item.state.xy[2] * 100))
 if currentvalue ~= colorvalue then
 grp.update(addr, colorvalue)
 addressmapping[item.name]['colorvalue'] = colorvalue
 log('lamp ' .. item.name .. ' color is: ' .. colorvalue)
 elseif item.state.colormode == 'ct' then
 --colortemp = math.floor((item.state.ct / 0.0769) + 0.5)  --0.0769230769230769
 colortemp = math.abs((item.state.ct - 500) / 2)
 colortemp = math.floor(colortemp + 0.5)
 colortemp = 80 + colortemp
 if colortemp > 255 then
 colortemp = 255
 r = lmcore.inttohex(255, 1)
 g = lmcore.inttohex(255, 1)
 b = lmcore.inttohex(colortemp, 1)
 rgb = r .. g .. b
 colortemp = lmcore.hextoint(rgb,3)
 if currentvalue ~= colortemp then
 --colortempconverted = ct_to_rgb(colortemp)
 grp.update(addr, colortemp)
 addressmapping[item.name]['colorvalue'] = colortemp
 log('lamp ' .. item.name .. ' color is: ' .. colortemp)
 --end
 --log('manufacturername = ' .. item.manufacturername)
 --log('swversion = ' .. item.swversion)
 --log('type = ' .. item.type)
 --log('ct = ' .. item.state.ct)
 --log('reachable = ' .. item.state.reachable)
 --log('alert = ' .. item.state.alert)
 --log('on = ' .. item.state.on)
 --log('bri = ' .. item.state.bri)
 --log('colormode = ' .. item.state.colormode)
 --log('hue = ' .. item.state.hue)
 --log('sat = ' .. item.state.sat)
 --log('effect = ' .. item.state.effect)
 --log('x = ' .. item.state.xy[1])
 --log('y = ' .. item.state.xy[2])
 --log('uniqueid = ' .. item.uniqueid)
 --log('modelid = ' .. item.modelid)
 --log('name = ' .. item.name)
 -- Delay loop
 os.sleep(interval)
 Thank you for all help :-)
	Threads: 45
		Calculate the reverse color temp like this: Code: colortemp = math.floor(1000000 / item.state.ct)
Keep in mind that there might be a difference between set and status values due to precision loss during when converting between Mireks and Kelvins.
	Threads: 2
		 (20.03.2019, 08:04)admin Wrote:  Calculate the reverse color temp like this:
still dont understand how to get this working in my resident script
Sorry for all my questions, but i still got a bit to learn about scripting .-)
Daniel
