11.04.2019, 19:11
Hi.
Why can i activate a port both as a input and a output at the same time?
Kai-Roger
Kai-Roger
CanX UIO8 (8 Universal IO ports + LoRa) (0.2)
11.04.2019, 19:11
Hi.
Why can i activate a port both as a input and a output at the same time? BR Kai-Roger
11.04.2019, 19:16
(11.04.2019, 19:11)Kai-Roger Wrote: Hi. it's not a bug, it's a feature)) when you will change value of output object, input value will change too. it's like real hardware status (not software) when you realy know that voltage on clamp is 24 v
11.04.2019, 19:27
(11.04.2019, 19:16)AEK Wrote:(11.04.2019, 19:11)Kai-Roger Wrote: Hi. So what you say, is that when i use it as output, the input object will change if i short circut the output? And this is to tell me that the output has a faulty condition?
11.04.2019, 19:42
(11.04.2019, 19:27)Kai-Roger Wrote:sorry, my english is not well, so if I mistake Admin and Edgar will fix my words.(11.04.2019, 19:16)AEK Wrote:(11.04.2019, 19:11)Kai-Roger Wrote: Hi. if you short circut the output and GND clamp this channel will go to fault mode. it will go to "off" state until you restart device by power supply. but with configuration on your screen if you will control relay you will have real status of output chanel, because input use other pins of device CPU
11.04.2019, 19:52
(11.04.2019, 19:42)AEK Wrote: sorry, my english is not well, so if I mistake Admin and Edgar will fix my words. So it is a better solution input as status object than just using the output status object of the output?
11.04.2019, 19:56
(11.04.2019, 19:52)Kai-Roger Wrote:I think yes, but its better to wait Admin's opinion(11.04.2019, 19:42)AEK Wrote: sorry, my english is not well, so if I mistake Admin and Edgar will fix my words.
