Gefen Integration
Hello again,
I need to setup a Gefen 4x2 UHD Matrix on a installation and I like to know if someone installed it before, I read it is possible to control the Matrix via IP... I add a user manual and I try to make a scrip to control it. BR.
.pdf   GTB-HD4K2K-442.pdf (Size: 6.43 MB / Downloads: 10)
Try this to set IP config over RS232 (if needed):
-- To set up IP control, the network settings for the 4K Ultra HD 4x2 Matrix for HDMI must be configured via RS-232.
-- RS232 Script to set IP control
-- Load Modules
require('serial')
-- Open connection
port = serial.open('/dev/RS232', {
 baudrate = 115200,
 databits = 8,
 stopbits = 1,
 parity = 'none',
 duplex = 'full'
-- Function to read until carier return is received or timeout
function readline(port, timeout)
 local char, buf
 buf = {}
 while true do
   char = port:read(1, timeout or 0.2)
   -- error (timeout) or newline, stop
   if char == nil or char == '\n' then
     break
   -- ignore cr char
   elseif char ~= '\r' then
     table.insert(buf, char)
 return table.concat(buf)
-- Function to write to port and return a reply
function writetoport(port, timeout, command)
    -- Write data to port as HEX
 port:write(command)
    -- Call function to read data
 line = readline(port, timeout)
 if #line > 0 then
     return line
   return "No reply received"
-- Send command to port and wait for reply or timeout
reply = writetoport(port, 1, '#sipadd 192.168.2.190')-- Timeout is set to 1 second (default = 0.2)
log(reply)
reply = writetoport(port, 1, '#snetmask 255.255.0.0')-- Timeout is set to 1 second (default = 0.2)
log(reply)
reply = writetoport(port, 1, '#sgateway 192.168.1.5')-- Timeout is set to 1 second (default = 0.2)
log(reply)
reply = writetoport(port, 1, '#set_telnet_port 23')-- Timeout is set to 1 second (default = 0.2)
log(reply)
reply = writetoport(port, 1, '#set_http_port 80')-- Timeout is set to 1 second (default = 0.2)
log(reply)
reply = writetoport(port, 1, '#set_udp_remote_ip 192.168.1.227')-- Timeout is set to 1 second (default = 0.2)
log(reply)
reply = writetoport(port, 1, '#set_udp_port 56')-- Timeout is set to 1 second (default = 0.2)
log(reply)
reply = writetoport(port, 1, '#set_udp_remote_port 50008')-- Timeout is set to 1 second (default = 0.2)
log(reply)
-- REBOOT MATRIX NOW
And after reboot try this to control:
-- Control over UDP
-- Function Udp Send
function udpsend(message,ip,port)
 require('socket')
 local client = socket.udp()
 if client then
   client:sendto(message,ip,port)
   client:close()
result, err = udpsend('#power 0','192.168.1.227', 50008) -- Command to power on
log(result)
result, err = udpsend('#power 1','192.168.1.227', 50008) -- Command to power off
log(result)
Not tested so i hope it works for you (;
Erwin van der Zwart
