24.04.2019, 13:16
(This post was last modified: 24.04.2019, 13:17 by MichelDeLigne.)
Would it be possible to add the libmcrypt library to LM?
I need to decode Rijndael 128 encrypted strings, which cannot be done in my case with the available libraries.
in some cases AES256 could be used if the key was 256bits long, but it is not the case here.
I found a proper lua library to do it, but unfortunately the required lib is missing from the system.
Here is the code I plan to use (from the same author as the one for aes from another thread).
I made a few changes to the code to hopefully make it work on the system.
Regards.
Michel.
12:24 2015/9/30 lilien
local ffi = require 'ffi'
local ffi_new = ffi.new
local ffi_str = ffi.string
local ffi_copy = ffi.copy
local setmetatable = setmetatable
local _M = { }
local mt = { __index = _M }
ffi.cdef[[
struct CRYPT_STREAM;
typedef struct CRYPT_STREAM *MCRYPT;
MCRYPT mcrypt_module_open(char *algorithm,
char *a_directory, char *mode,
char *m_directory);
int mcrypt_generic_init(const MCRYPT td, void *key, int lenofkey,
void *IV);
void free(void *ptr);
void mcrypt_free(void *ptr);
int mcrypt_enc_get_key_size(const MCRYPT td);
int mcrypt_enc_get_supported_key_sizes(const MCRYPT td, int* len);
int mcrypt_generic_deinit(const MCRYPT td);
int mcrypt_generic_end(const MCRYPT td);
int mdecrypt_generic(MCRYPT td, void *plaintext, int len);
int mcrypt_generic(MCRYPT td, void *plaintext, int len);
int mcrypt_module_close(MCRYPT td);
int mcrypt_enc_mode_has_iv(MCRYPT td);
int mcrypt_enc_get_iv_size(MCRYPT td);
int mcrypt_enc_is_block_mode(MCRYPT td);
int mcrypt_enc_get_block_size(MCRYPT td);
local mcrypt = '/usr/lib/libmcrypt.so'
if not io.exists(mcrypt) then
mcrypt = '/usr/lib/libmcrypt.so.4'
ffi.load(mcrypt, true)
_M.new = function (self)
local cipher = 'rijndael-128'
local mode = 'ecb'
local c_cipher = ffi_new("char[?]",#cipher+1, cipher)
local c_mode = ffi_new("char[4]", mode)
local td = mcrypt.mcrypt_module_open(c_cipher, nil, c_mode, nil)
return setmetatable( { _td = td }, mt )
_M.pass = function (self, key, raw,enc_or_dec)
local dencrypt = enc_or_dec
local iv_len = 8
local mode = 'ecb'
if td ==0 then
ngx.log(ngx.ERR , "mcrypt_module_open failed")
return nil
local iv_key = "1234567890123456";
local key_len= #key;
local data_len= #raw;
local block_size, max_key_length, use_key_length, i, count, iv_size;
--/* Checking for key-length */
max_key_length = mcrypt.mcrypt_enc_get_key_size(td);
if key_len > max_key_length then
ngx.log(ngx.ERR , "Size of key is too large for this algorithm key_len:",key_len,",max_key:",max_key_length)
return nil
count = ffi_new("int[1]")
local key_size_tmp = mcrypt.mcrypt_enc_get_supported_key_sizes(td, count);
local key_length_sizes = ffi.cast("int *",key_size_tmp)
local key_s = nil;
if count[0] == 0 and key_length_sizes == nil then --/* all lengths 1 - k_l_s = OK */
use_key_length = key_len;
key_s = ffi_new("unsigned char[?]",use_key_length,key)
if count[0] == 1 then
key_s = ffi_new("char[?]",key_length_sizes[0])
ffi.fill(key_s ,use_key_length,0);
ffi.copy(key_s, key, math.min(key_len, key_length_sizes[0]));
use_key_length = key_length_sizes[0];
use_key_length = max_key_length;
for i=0,count[0]-1 do
if key_length_sizes[i] >= key_len and key_length_sizes[i] < use_key_length then
use_key_length = key_length_sizes[i];
key_s = ffi_new("char[?]",use_key_length)
ffi.copy(key_s ,key, math.min(key_len,use_key_length));
if key_length_sizes~=nil then
mcrypt.mcrypt_free(key_length_sizes);
local iv_s = nil;
local iv_size = mcrypt.mcrypt_enc_get_iv_size (td);
local has_iv = mcrypt.mcrypt_enc_mode_has_iv(td) ;
local data_size = 0;
local block = mcrypt.mcrypt_enc_is_block_mode(td);
if block == 1 then
block_size = mcrypt.mcrypt_enc_get_block_size(td);
data_size = math.floor(((data_len - 1) / block_size) + 1) * block_size;
data_size = data_len;
local data_s = ffi_new("char[?]",data_size)
ffi.fill(data_s ,data_size,0);
ffi.copy(data_s ,raw ,data_len);
local ini_ret = mcrypt.mcrypt_generic_init(td, key_s, use_key_length, c_iv)
if ini_ret < 0 then
ngx.log(ngx.ERR , "Mcrypt initialisation failed");
ngx.say( ini_ret,"ini_ret initialisation failed");
return nil
if dencrypt == 1 then
mcrypt.mcrypt_generic(td, data_s, data_size);
mcrypt.mdecrypt_generic(td, data_s, data_size);
local ret_str = ffi_str(data_s,data_size);
mcrypt.mcrypt_generic_end(td);
return ret_str
_M.encrypt = function (self, key, raw)
return _M.pass(self, key, raw,1);
_M.decrypt = function(self, key, raw)
return _M.pass(self, key, raw,0);
_M.close = function(self)
local td = self._td
if td then
mcrypt.mcrypt_module_close(td)
return _MRegards.
Michel.
