Convert base64 to decimal
hii guys,
I want to convert a base64 value to decimal, but I cant get it to work.
Only command I'm seeing is encdec.base64dec(str) . Any suggestions?
Can you post an example of your data? Do you have binary representation of an integer encoded using base64? Does it have fixed length?
(16.05.2019, 07:51)admin Wrote: Can you post an example of your data? Do you have binary representation of an integer encoded using base64? Does it have fixed length?
I get data from an https.request, no fixed length. For example:
decimal 1 --> the data I get from the request (base64): AQ==
Now I want to decode back to decimal or HEX
You can convert binary string to hex by using lmcore.strtohex()
