14.06.2019, 09:48
strange group address broadcast on LM?
14.06.2019, 21:13
(14.06.2019, 09:48)gtsamis Wrote:(13.06.2019, 15:51)puntukas Wrote: Daniel: yes, sending two telegrams to different group address. Nothing connected to address in trouble. I did it. Nothing changes. As LM restarts - it generates these telegrams, so I think the reason is somewhere in LM ![]()
14.06.2019, 21:56
(This post was last modified: 14.06.2019, 22:00 by Erwin van der Zwart.)
As sender is “bus” that is not possible in my opinion..
If you are so sure it comes from the controller then you need to check objects if read during startup is checked or if read interval is > 0 and check your scripts and startup script and custom JS (JS can only run when a client is active). Check if any tag is linked to the object that you might have overlooked. There is no way the controller does this on its own without any cause activated from items above... Can you disable KNX IP features on the reboot to be sure it does not come from IP somewhere? BR, Erwin
21.06.2019, 20:16
Thanks, Erwin!
I disabled KNXIP on LM, rebooted and telegrams did not showed up. When I enabled and rebooted - two telegrams generated. If it comes from other device - why telegrams are generated after reboot? I even deleted 3 startup lines - the same: 2 telegrams generated. Thanks...
24.06.2019, 07:43
Send me your backup to PM. I will check if it happens on my network too. If yes then it is LM problem if not, your installation somewhere else. BR
06.07.2023, 15:39
Was this case solved ? What was the solution for this issues ?
06.07.2023, 16:41
You wouldn't expect us to remember this after 4 years.
Ctrl+F5 |
