21.05.2019, 09:15
(10.01.2019, 09:55)admin Wrote: Thanks!
First, you need to update MQTT library packages:
New CPU:
https://dl.openrb.com/pkg/libmosquitto_1...1_imx6.ipk
https://dl.openrb.com/pkg/luamosquitto_0.3-2_imx6.ipk
Old CPU:
https://dl.openrb.com/pkg/libmosquitto_1.4.15-1_mxs.ipk
https://dl.openrb.com/pkg/luamosquitto_0.3-2_mxs.ipk
Here's a minimal example that you can use, don't forget to change device_id, broker, username and password parameters. You also need to upload azure.crt via FTP (using ftp username, upload to root directory). Certificate file contents: https://gist.github.com/jsopenrb/5873b20...d6b950151f
Code:device_id = 'DEV_TEST' broker = 'DEV.azure-devices.net' port = 8883 username = 'DEV.azure-devices.net/DEV_TEST' password = 'SharedAccessSignature ...' mqtt = require('mosquitto') client = mqtt.new(device_id) client.ON_CONNECT = function(...) log('ON_CONNECT', ...) client:publish('devices/' .. device_id .. '/messages/events/', '{id=456}') end client.ON_PUBLISH = function(...) log('ON_PUBLISH', ...) end client.ON_LOG = function(...) log('ON_LOG', ...) end client.ON_DISCONNECT = function(...) log('ON_DISCONNECT', ...) end client:version_set(mqtt.PROTOCOL_V311) client:tls_set('/home/ftp/azure.crt') client:login_set(username, password) client:connect(broker, port) while true do res, err, code = client:loop() if not res then log('loop error', res, err, code) os.sleep(1) end end
Is there a typo in the filename or is the package removed from your downloads?
libmosquitto_1.4.15-1_imx6.ipk
