Threads: 29
hi
in the json modbus, i would like to do divede (/10) the value .
is there fix?
"name": "load_output",
"bus_datatype": "14",
"type": "register",
"address": 175,
"writable": "true"
thanks
Threads: 7
Use this:
"value_multiplier" :
0.1 ,
Threads: 29
(22.09.2019, 22:27) Erwin van der Zwart Wrote: Hi,
Use this:
0.1 ,
ErwinHI
Erwin not working.
Threads: 43
(23.09.2019, 04:47) balatis Wrote: (22.09.2019, 22:27) Erwin van der Zwart Wrote: Hi,
Use this:
0.1 ,
Erwin HI
Erwin not working.
Have you checked your commas?
"name" :
"load_output" ,
"bus_datatype" :
"14" ,
"type" :
"register" ,
"address" :
175 ,
0.1 ,
"writable" :
"true"
Threads: 29
(23.09.2019, 09:52) gtsamis Wrote: (23.09.2019, 04:47) balatis Wrote: (22.09.2019, 22:27) Erwin van der Zwart Wrote: Hi,
Use this:
0.1 ,
Erwin HI
Erwin not working.
"name" :
"load_output" ,
"bus_datatype" :
"14" ,
"type" :
"register" ,
"address" :
175 ,
0.1 ,
"writable" :
"true"
Hi Erwin Yes the command is ok .
Threads: 43
Can you read raw value with RTU read test? Try setting bus datatype as a number without quotes:
"name" :
"load_output" ,
"bus_datatype" :
14 ,
"type" :
"register" ,
"address" :
175 ,
0.1 ,
"writable" :
true
Make sure to create new device from scratch when uploading new profile. Because existing devices will still use old profile data.
