json
hi
in the json modbus, i would like to do divede (/10) the value .
is there fix? Huh
"name": "load_output",
"bus_datatype": "14",
"type": "register",
"address": 175,
"writable": "true"
thanks
Use this:
"value_multiplier": 0.1,
(22.09.2019, 22:27)Erwin van der Zwart Wrote: Hi,
Use this:
HI
Erwin not working.
Use this:
HI
Erwin not working.
Have you checked your commas?
{ "name": "load_output", "bus_datatype": "14", "type": "register", "address": 175, "value_multiplier": 0.1, "writable": "true" }
Use this:
HI
Erwin not working.
Hi Erwin Yes the command is ok .
Can you read raw value with RTU read test? Try setting bus datatype as a number without quotes:
{ "name": "load_output", "bus_datatype": 14, "type": "register", "address": 175, "value_multiplier": 0.1, "writable": true }
Make sure to create new device from scratch when uploading new profile. Because existing devices will still use old profile data.
