Threads: 58
Hi all,
can you tell me which current firmware includes BACnet for SpacelYnk and Wiser For Knx?
Where can I download an official version ?
Thank's in advance for your answer.
All the best from France.
Threads: 28
All of them had it. Download it from se.com
Threads: 58
Ok ... BACnet server is native in SpaceLynk!
Thank you Daniel
Threads: 58
Dear Erwin,
I installed the package "Wiser_for_KNX-2.4.0_hw1.xx.img" on my Wiser For Knx "2.3.0", and then, after a reeboot, it's always the same "2.3.0" release number writed à the botton left of the creen !
PS: after new firmware upload : 2.3.0 / Flashsys v2 / ©2008-2018
Any reasons ?
Thank's in advance...
Threads: 28
clear browser cache
Threads: 58
same thing...
The "system > Firmware Upgrade" indicate "SW 2.3.0" !
Threads: 28
card in read only mode?
Threads: 58
Which card ? I have already made several firmware updates without any problem...
Threads: 28
Change any system settings, press sync and then reboot. Check if this what was changed is still there.
Threads: 39
20.02.2020, 19:51
(This post was last modified: 20.02.2020, 19:53 by domotiqa .)
(09.10.2019, 13:23) Daniel. Wrote: Change any system settings, press sync and then reboot. Check if this what was changed is still there.
I have the same problem with spacelynk imx28 of a customer version 2.1.1 that could not upgrade to 2.4 hw1.
The upgrade process running well.
But after still in 2.1.1.
I would try to 2.3 but can't find in hw1. Only broken link:
https://www.se.com/es/es/faqs/FA322491/
I already try the cache, change settings, sync...
any idea ?
SE ECO EXPERT
Threads: 28
The SD card is most likely in read only mode and has to be replaced.
Threads: 39
20.02.2020, 20:38
(This post was last modified: 20.02.2020, 20:45 by domotiqa .)
(20.02.2020, 20:20) Daniel. Wrote: The SD card is most likely in read only mode and has to be replaced.
ok thank you, I will check the tutorial.
But just a question:
- I can modify the program... (stored in flash ??)
- I didn't have a message in log
EDIT:
I found in system log:
Feb 20 19 :
44 :
47 fca-knx kern.info kernel : [
1.295589 ]
VFS :
Mounted root (
ext3 filesystem )
readonly on device 179 :
2.
Feb 20 19 :
44 :
1.295415 ]
EXT4-fs (
mmcblk0p2 ):
mounted filesystem with ordered data mode. Opts : (
null )
Feb 20 19 :
44 :
1.293130 ]
EXT4-fs (
mmcblk0p2 ):
recovery complete
Feb 20 19 :
44 :
0.854610 ]
EXT4-fs (
mmcblk0p2 ):
write access will be enabled during recovery
Feb 20 19 :
44 :
0.854553 ]
EXT4-fs (
mmcblk0p2 ):
INFO :
recovery required on readonly
SE ECO EXPERT
Threads: 28
In this HW everything is stored in SD, there was no SPI flash on imx28.
