Weird behaviour with nested tables and log
I am going crazy....
Working on a scheduled script and running it manually to check it.
The code below neither print AAAAAAAAAA nor BBBBBBBBBBBB.
However, if I comment out line 19 (log('DDDDDDDDDDD')), everything is printed out fine.
What am I missing?
Dodgy
Thanks in advance for any good input
Rgds
Christian
CODE:
log('AAAAAAAAAAAAAAAAAAAAAAAAAAAA')
tPresenceCheck = {
  {'Area1', 10 , '0/200/0' , {'21/4/19','24/4/19'}},
  {'Area2', 15 , '5/200/0' , {'21/4/19','24/4/19','25/4/9'}}
log('BBBBBBBBBBBBBBBBBBBBBBBBBB')
log(tPresenceCheck)
log(#tPresenceCheck)
for i=1,#tPresenceCheck do
  log('CCCCCCCCCCCCCCCCCCCCCC')
  tCurr = tPresenceCheck[i]
  log(tCurr)
  sArea = tCurr[1]
  log(sArea)
  log('DDDDDDDDDDDDDDDD')
Not sure if it’s always needed but you are missing the step size of the for loop.
for start, stop, step do, in your case for i=1,#tPresenceCheck, 1 do
Step is optional, but it's better to use ipairs for loop. Do you have anything in error logs?
(30.12.2019, 09:11)Erwin van der Zwart Wrote: Hi,
Thx for the quick reply.
LUA should default the step size to 1 if missing.
Tried anyway to add ,1 but in vain.
It is really odd. I can actually comment out any one of the four "log" statements inside the for-loop and things will work fine.
Once all log statements are there, I do not get any AAAAAAAAA or BBBBBB.
Is it something basic I am missing?
Thx
Rgds
Christian
Try removing all spaces/tabs before statements in for loop.
Here is another (simpler) example that is not working.
The code below does not print the "AAAAAAAAAAAAAAA" (the first line statement).
If I comment out the log statement in the inner for-loop, everything works fine.
CODE:
log('AAAAAAAAAAAAAAAAAA')
local pid = os.getpid()
spid = ' (pid=' .. pid .. ')'
log('STARTING SCRIPT ' .. _SCRIPTNAME .. spid)
log('BBBBBBBBBBBBBBBBBBB')
for i=1,2,1 do
log( 'CCCCCCCCCCCCCCCCCC')
  for j=1,3,1 do
OUTPUT:
ZZTest 30.12.2019 12:04:03
* string: STARTING SCRIPT ZZTest (pid=5393)
* string: BBBBBBBBBBBBBBBBBBB
* string: CCCCCCCCCCCCCCCCCC
* string: DDDDDDDDDDDDDDDD
Check in LM log tab, it is there.
(30.12.2019, 11:21)Daniel. Wrote: Check in LM log tab, it is there.
Wow!
Thanks so much.
I was only looking at the log window which you can pop-up from the code editor.
In this log-window, apparently not all logs are captured. Weird!, but good to know.
HAPPY NEW YEAR
Rgds
Christian
Smile
