Support for RS256 (RSA Signature with SHA-256)
Does encdec support rsa with sha256? I would like to generate a JWT token.
I found this library https://github.com/spacewander/lua-resty...ty/rsa.lua, which seems to use openssl. I believe this is installed and should work?
Would the usage then be similar as described in this post?
https://forum.logicmachine.net/showthrea...7#pid10237
Do I need to do anything special to use the bitops?
http://bitop.luajit.org/
See this: https://forum.logicmachine.net/showthrea...2#pid15322
(20.01.2020, 13:09)admin Wrote: See this: https://forum.logicmachine.net/showthrea...2#pid15322
Hi, I am not sure if the encdec or AES implementation are the same as the RSA encryption, in the JWT spec https://tools.ietf.org/html/rfc7518#section-3 I read RS256 is equal to RSASSA-PKCS1-v1_5 using SHA-256. Are you suggesting to calculate the signature myself using the hmacsha256 of encdec instead of using the openssl implementation?
Here are JWT libraries from https://github.com/cdbattags/lua-resty-jwt with some minor changes to work on LM. Create a use library with the same name for each attached file.
jwt = require "user.jwt" jwt_token = jwt:sign(   "my-secrect-key",   {     header={typ="JWT", alg="HS256"},     payload={foo="bar"}   } ) log(jwt_token)
.lua   evp.lua (Size: 17.46 KB / Downloads: 14)
.lua   aes.lua (Size: 6.57 KB / Downloads: 18)
.lua   hmac.lua (Size: 3.67 KB / Downloads: 15)
.lua   jwt.lua (Size: 28.69 KB / Downloads: 16)
.lua   jwt-validators.lua (Size: 14.92 KB / Downloads: 13)
(27.01.2020, 07:40)admin Wrote: Here are JWT libraries from https://github.com/cdbattags/lua-resty-jwt with some minor changes to work on LM. Create a use library with the same name for each attached file.
I get
Quote:User library hmac:85: Symbol not found: EVP_md5
stack traceback:
[C]: in function '__index'
User library hmac:85: in main chunk
[C]: in function 'require'
Library user-autoload:5: in main chunk
Tried to upgrade to the latest firmware, but that did not resolve the issue. I am using a LM3 Reactor v2.
You need to disable auto-load for this library. user.aes must be loaded first because it loads ssl library, otherwise you will get this error.
