CPU Load Log as Trend
Hello everyone,
Does anyone know how could I get the CPU load as a 2byte value (virtual object) and then make a Trend Log with a resolution of 1sec or log by delta change = 1% of CPU usage?
What I need to achieve is a historic data log from the CPU usage.
Kind regards and thank you for any help in advance
This will give you load and memory
data = io.readfile('/proc/meminfo') load = io.readfile('/proc/loadavg'):split(' ')[ 1 ] memtotal = data:match('MemTotal:%s+(%d+)') memavail = data:match('MemAvailable:%s+(%d+)') memusage = math.floor((memtotal - memavail) / memtotal * 1000) / 10 log(tonumber(load), memusage)
(10.09.2019, 13:37)Daniel. Wrote: This will give you load and memory
Hello Daniel.
Thank you for your reply.
I am getting values 0.24 , 0.25 ... Does this mean the CPU load is 0.24 %?
No it is not percentage, it is bit more complicated in linux. Try reading this
https://www.tecmint.com/understand-linux...rformance/
To write to object just do it like that:
grp.update('1/1/1', tonumber(load))
(10.09.2019, 14:02)Daniel. Wrote: No it is not percentage, it is bit more complicated in linux. Try reading this
Yes I figured out how to write the value to the object but the Load average is indeed complicated. So then it will require a script to calculate properly the % of CPU load average for the last 1min.
Does anyone have a solution for this?
Use this script to log CPU load to an object. Resident script sleep time controls how often load is calculated.
data = io.readfile('/proc/uptime'):split(' ') total, idle = tonumber(data[ 1 ]), tonumber(data[ 2 ]) if prevtotal then   deltatotal = total - prevtotal   deltaidle = idle - previdle   load = math.floor((1 - (deltaidle / deltatotal)) * 100 + 0.5)   grp.update('32/0/0', load) end prevtotal, previdle = total, idle
Thank you Admin. As always works perfectly.  Smile
(11.09.2019, 06:33)admin Wrote: Use this script to log CPU load to an object. Resident script sleep time controls how often load is calculated.
What datatype would appropiate for this output`?
Best regards, Jørn.
5.001 - 0..100%
