Hello
I have written the following script to control the power off of an LG TV using the RS232 serial port.
The scrip works perfectly and the TV turns on, the command changes the value to turn it off and on, to write without problem. I have a log of the message that is sent and it is correct.
Now what I want is to manage the confirmation of messages, according to the TV manual, the response has the following format:
[Comando 2][Espacio][Set ID][OK][Dato][x] --- for correct reception.
[b][Comando 2][Espacio][Set ID][NG][Dato][x] --- for incorrect reception.[/b]
This is when the problems come, I read 10 bytes from the port, the question is that the answers obtained in the log appear bytes from previous answers, so I don't know how to discriminate them.
This is the result of the log, after sending several commands to turn on in a row.
RS232 26.05.2020 13:30:03
* string: ka 01 01
* string: 01 NGxa 01
RS232 26.05.2020 13:30:35
* string: ka 01 01
* string: OK01xa 01
I have tried the flush function before and after reading but nothing.
Or do I have to reset the variable "res" before reading the port?
Any ideas?
Thank you.
-- Se obtiene el valor del objeto de escenas y se guarda en la variable value
value = event.getvalue()
-- si el valor de la variable value es igual a 3 (número de escena), entonces enviamos el comando de encendido
if (value == 3) then
-- Es necesario incluir la librería de las funciones de comunicación serie
if not port then
require('serial')
-- Configuración y apertura del puerto serie
port = serial.open('/dev/RS232', {
baudrate = 9600,
databits = 8,
stopbits = 1,
parity = 'none',
duplex = 'full'
-- Limpiar bytes no leídos o enviados
port:flush()
-- Escribir datos en el puerto serie para encender la TV
msg = string.char(0x6B, 0x61, 0x20, 0x30, 0x31, 0x20, 0x30, 0x31, 0x0D)
port:write(msg)
log (msg) -- Esta línea permite ver el comando en el registro para comprobar que se está enviando
port:flush()
res = port:read(10)
log (res) -- Esta línea permite ver el comando en el registro para comprobar que se está recibiendo
port:flush()
port:close()
* string: ka 01 01
* string: ka 01 01
* string: OK01xa 01
Any ideas?
Thank you.
